TC10's avatar
TC10
Tutor
Nov 05, 2020
when Netgear updates firmware or app and product stops working do they support?
My orbi network is working but my orbi app on ihpone will not connect and my orbi web app has errors.  Is there any way to get Orbi help as this seems to have happened when I upgraded to ios14 on iphone se2020.
  • FURRYe38's avatar
    Has a power off for 1 minute then back on been performed since last update?
  • Many other people are having this same trouble. It looks like Netgear broke the Orbi iOS app with the latest release.
    Do you also have the Nighthawk app on your phone from a previous router? If so, delete it.
