kciociola
Feb 03, 2023Aspirant
When PC is off, ethernet ports on Orbi RBR50 don't work
I have a (1) Lenovo Windows PC (connected to ethernet via a docking station) and (2) ethernet hub connected to separate ports on the back of an Orbi RBR50. The third port is unused. Whenever the ...
Feb 03, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What are these "hubs" connected in back?
What CAT# LAN cable are you using between devices?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Disconnect everything accept for one wired PC. Then graduate adding a device and test the ports.
- kciociolaFeb 04, 2023Aspirant
Orbi firmware: 2.7.4.24
Modem: Arris TM1602A
Hub: Netgear GS305v3
Everything is connected with CAT5
First thing I did was to check the firmware of the router to make sure there were no updates.
I haven't done the power cycling routine since any updates, but this is a problem that predates any LAN hardware updates—in fact, I think this is a "Day One" issue with the Orbi. The PC is rarely off, but when it does turn off, I lose connectivity to the hub.
I'll find time to follow your troubleshooting steps. Thank you for the tip!
- FURRYe38Feb 05, 2023Guru - Experienced User
Disconnect the GS-305 swtich then connect everything to the RBR.
I would upgrade the cables to CAT6. CAT5 is only officially supporting of 100Mpbs, not 1000Mpbs.
