Retired_Member
Feb 03, 2017When will Orbi support multicast?
Any idea when Orbi will support multicast for IPTV? Currently YouView/BTTV won't work with Orbi in router mode. I saw a thread that had a post from Netgear Support on a German Amazon comments section...
Retired_Member
Feb 22, 2017I still can't get BT TV or any multicast stream to work. I have the BT TV wired directly to the Orbi router. I have unticked "Disable IGMP Proxying" and have ticked "Support British telecom IGMP Proxying". I've rebooted everything several times.
Anyone get this working?
FrancesH
Feb 22, 2017Tutor
Same here. Unchecked disable IGMP Proxying, unplug and reset my Marantz 8802A. Still no dice. Airplay still not active on the Marantz alone. Other Apple devices are on.
The only variant here is the Marantz is direct to router and the rest are on WIFI. It was working fine with Linksys before, but it stopped working since Orbi was online.
