gadget13
Nov 10, 2019Aspirant
Where are the device names located when in a telnet session?
Several of us are having issues renaming devices on our network. I want to take the GUI out and go to the source via a telnet session. So my question is - where is the device name stored so that I ca...
gadget13
Nov 12, 2019Aspirant
I simply applied the v40FW to the router and satelites.
After they reboot the device name duplication was gone and I was able to start setting names as I wanted.
tomschmidt
Nov 12, 2019Virtuoso
I manually updated my firmware from V2.5.0.38 to V2.5.0.40 to see if it would also fix the device naming issue. It did for some devices, but others it will not allow me to change. So the v40 hot fix did not resolve the device naming issue. Note that I did not do a factory reset as it takes me hours to reconfigure the device manually.
- migstaNov 13, 2019Apprentice
Netgear has abosolutely no clue whatsoever about how to fix this devices issue. And, it may be because nobody at Netgear is in sync with respect to this issue existing. Device renaming and devicy type selection is completey BROKEN at all levels and it exists with Orbi and RAXxxx series routers. And, it has been there for several firmware level nows. I've tried 3 fresh RBR50's and they all exhibit the devices issue so has nothing to do with resetting to factory default to fix it. And, today I received a note from Netgear support to update to 2.5.0.30 to address my issue (unless he meant 2.5.0.40) which I see here as may or may not fixing the devices issue. I'm at 2.5.0.38 and devices is broken there as it is broken on 2.5.0.30. And, like I said in another post - they release 2.5.0.38 with updated device type selections as a feature of this release BUT device renaming and device type selection doesn't work - how would they have tested this as passed????
- FURRYe38Nov 13, 2019Guru - Experienced User
You might give v40 a try and see if it works for you, if not you can always revert back. Won't know unless you try.
I would factory reset the RBR and setup from scratch to give the new FW a chance to detect your devices correctly if you choose to give v40 a try.
migsta wrote:Netgear has abosolutely no clue whatsoever about how to fix this devices issue. And, it may be because nobody at Netgear is in sync with respect to this issue existing. Device renaming and devicy type selection is completey BROKEN at all levels and it exists with Orbi and RAXxxx series routers. And, it has been there for several firmware level nows. I've tried 3 fresh RBR50's and they all exhibit the devices issue so has nothing to do with resetting to factory default to fix it. And, today I received a note from Netgear support to update to 2.5.0.30 to address my issue (unless he meant 2.5.0.40) which I see here as may or may not fixing the devices issue. I'm at 2.5.0.38 and devices is broken there as it is broken on 2.5.0.30. And, like I said in another post - they release 2.5.0.38 with updated device type selections as a feature of this release BUT device renaming and device type selection doesn't work - how would they have tested this as passed????
