dante928
Jan 08, 2021Aspirant
Where do I change the channel on ORBI RBR20?
Where do I change the channel on ORBI? I don't see it on my app or on the website. Wi-FI constantly droppin because it seems there is too much traffic. HELP!
Jan 08, 2021Guru - Experienced User
On the RBRs web page using a PC or laptop and web browser pointed at orbilogin.com or 192.168.1.1.
dante928
Thank you for your reply. I am technically challenged and this is hard for me to understand.
- FURRYe38Jan 08, 2021Guru - Experienced User
To change the channels, you need a PC or laptop connected to the Orbi system. Use a web browser to nagivate to the RBRs web page and log in to the web page. Under Basic Tab/Wireless section, you'll see where to change channels if you need too.
Find a family member, neighbor or a friend who can help you with this.
Review the user manual as well.
dante928 wrote:Thank you for your reply. I am technically challenged and this is hard for me to understand.
- vajimJan 08, 2021Master
FURRYe38 wrote:To change the channels, you need a PC or laptop connected to the Orbi system. Use a web browser to nagivate to the RBRs web page and log in to the web page. Under Basic Tab/Wireless section, you'll see where to change channels if you need too.
And consider what your neighbors may be doing if any
