Horace0907
Apr 05, 2019Aspirant
Where should I put the satellites
The Router is far away from the satellite 10meters, the satellite only receive 10mbs. Between the router and the satellite, there is a room with two concrete walls and 3 closets. However, my plan is 5...
SW_
Apr 05, 2019Prodigy
You can try it out first. Move the Satellite to the middle of the room, where you would put the new Satellite and do a speedtest. Then you can decide if you really need a new Satellite or not.
- Horace0907Apr 05, 2019AspirantIf I put the third satellite, will this increase the speed?
- SW_Apr 05, 2019Prodigy
If moving the Satellite to the middle of the room shows good speed, you will get better 10Mbps speed with a third one. This is possible because of Daisy-Chain feature between the two Satellites to extend the signal and larger coverage.
Before you get a third one, try the speedtest in all the area of interest to see if you are happy with the speedtest result. If you are lucky, you might not need a third Satellite if moving the current Satellite to the middle of the room resolves your speed problem.
