Horace0907
Apr 05, 2019Aspirant
Where should I put the satellites
The Router is far away from the satellite 10meters, the satellite only receive 10mbs. Between the router and the satellite, there is a room with two concrete walls and 3 closets. However, my plan is 5...
Apr 06, 2019Guru - Experienced User
Horace0907 wrote:
The Router is far away from the satellite 10meters, the satellite only receive 10mbs. Between the router and the satellite, there is a room with two concrete walls and 3 closets. However, my plan is 500mbs and I have tested the speed with the router is around 400mbs. Should I add more one rbs in the middle o f the room?
The minimum distance desired between router and satellite is 30 ft (10 meters). so you're correct in your distance. Your problem is concrete. Concrete is amazing at blocking wifi signals. Amazing. If you want faster speeds, adding a satellite isn't going to help if the concrete is still blocking. If you can figure out an angle that will remove that concrete from the connection between router and satellite, your speeds will increase significantly.
