Horace0907
Apr 05, 2019Aspirant
Where should I put the satellites
The Router is far away from the satellite 10meters, the satellite only receive 10mbs. Between the router and the satellite, there is a room with two concrete walls and 3 closets. However, my plan is 5...
Apr 06, 2019Guru - Experienced User
If you're unable to work an angle that removes the concrete from the equation, do you have a drop ceiling since you have concrete walls? If so, you could run a wire through the ceiling and hardwire the router and satellite together. Much cheaper than buying another satellite that isn't going to give you much improvement because of the concrete.
Horace0907
Apr 06, 2019Aspirant
So i should return it?
- plemansApr 06, 2019Guru - Experienced User
Horace0907 wrote:
So i should return it?I didn't say you should return it. It doesn't matter which router you run, the concrete is going to block signal. If you can find a way to hardwire in a satellite or figure out an angle for connection, the orbi will give you the most seamless coverage you're likely to get. Play with placement or running a wire. Just letting you know concrete does a great job of blocking signal.
Personally, if you have a drop ceiling/false ceiling or anyway of running a cable, I'd hardwire in the satellite. Your house is going to struggle with wifi but that'd give you the best coverage.
I'm at work so I can't do anything fancy but I sketched a little drawing with what I mean by changing angles. Square in one corner is router and satellite on other end. Its really rough :) sorry --- Anything to go around the concrete.
- Horace0907Apr 06, 2019AspirantBecause I do not have a ceiling to let the wire connect the router and the satellite. I will try to find the best solution for it.
