majormcrae
May 22, 2021Initiate
Where to buy satellites for RBK50 or what satellite is compatible?
I am trying to extend my system. Home is right around 6,000 sqft, 3 stories and need better coverage in the basement. What satellite is compatible with the RBK50 system or where can I buy 2 satelli...
- May 23, 2021
IF actual RBS units can't be found, you can try a EX7500/7700 or 8000 extenders work with Orbi systems.
CrimpOn
May 22, 2021Guru - Experienced User
majormcrae wrote:I am trying to extend my system. Home is right around 6,000 sqft, 3 stories and need better coverage in the basement. What satellite is compatible with the RBK50 system or where can I buy 2 satellites for my RBK50 system?
Compatible satellites include:
RBS50, RBS40, RBW30, RBS20, RBS50Y,RBS40V
(The RBS10 is not compatible. Nor are "Pro" or "AX" models.)
Yes, satellites for the 2016 Orbi are becomming more and more difficule to find.
- alokeprasadMay 23, 2021Mentor
While RBS40, RBW30, RBS20 are compatible, the peak speeds supported by these are different as are the # of antennae and coverage areas.
I have been finding good (1 day) deals on Woot for these.
