majormcrae
May 22, 2021Initiate
Where to buy satellites for RBK50 or what satellite is compatible?
I am trying to extend my system. Home is right around 6,000 sqft, 3 stories and need better coverage in the basement. What satellite is compatible with the RBK50 system or where can I buy 2 satelli...
- May 23, 2021
IF actual RBS units can't be found, you can try a EX7500/7700 or 8000 extenders work with Orbi systems.
CrimpOn
May 22, 2021Guru - Experienced User
majormcrae wrote:I am trying to extend my system. Home is right around 6,000 sqft, 3 stories and need better coverage in the basement. What satellite is compatible with the RBK50 system or where can I buy 2 satellites for my RBK50 system?
Compatible satellites include:
RBS50, RBS40, RBW30, RBS20, RBS50Y,RBS40V
(The RBS10 is not compatible. Nor are "Pro" or "AX" models.)
Yes, satellites for the 2016 Orbi are becomming more and more difficule to find.
alokeprasad
May 23, 2021Mentor
While RBS40, RBW30, RBS20 are compatible, the peak speeds supported by these are different as are the # of antennae and coverage areas.
I have been finding good (1 day) deals on Woot for these.
