SpartanMurph
Mar 06, 2021Guide
Where to find an add-on satellite?
Currently have this https://www.amazon.com/dp/B07CQDHPFT/ref=cm_sw_r_cp_apa_fabc_AQKN9PMQH3Q13JR1N5T2?_encoding=UTF8&psc=1 Where can I buy one add-on satellite? Can't seem to locate one anywher...
SpartanMurph
Mar 07, 2021Guide
There was no drop down selection for the RBK23. So I chose the closest thing.
Thanks for your response. Essentially, they're out of production and hard to find.
The whole system was $300.00. can't imagine paying $300 for one add-on.
I'll hold off and invest in a whole new - newer wifi6 system in a year or two.
Mar 07, 2021Guru - Experienced User
You can get the RBS40v which is the same as the RBS20 accept it has voice controls fo 160 or 80 for use used one:
Well worth it IMO.
