sentavita
May 16, 2021Aspirant
Which Mesh System for 5 storey Terrace House
I live in a 5 storey terrace house with VERY thick walls. I would like an Orbi system and plan to have a satellite on every floor. Which one would you recommend? Price is not an issue, just want...
CrimpOn
May 16, 2021Guru - Experienced User
There is not enough information for anyone to make a proposal.
- What are the dimensions of each floor?
- Are these thick walls interior on every floor?
- Is it possible to connect all of the satellites to the router with ethernet cable?
- What is the internet feed? (cable? fiber? speed?)
- Where does the internet feed come into the house? (which floor?)
- What prompted the choice of Netgear Orbi vs. other systems?
- Are Parental Controls important?
- How many devices of what types are expected to connect to this system?
