cndee
Mar 20, 2018Aspirant
Which model of Orbi should I purchase and can I still use my WN2500RP N600 WiFi Range Extender?
I currently have a Verizon FIOS router and a WN2500RP N600 WiFi Range Extender. If I purchased the RBK30, can I still use my N600 Range Extender or should I replace the N600 and get a different mod...
- Mar 21, 2018
I have similar set up here. New addtion house with older existing house.
I would give the AC2200 RBK40 kit a try. Mines working great for me in my home. I don't think you'll need more then one Satellite. I would test with the router alone at first then see if you need to place the Satellite if needed.
Let us know what you decide to get.
Mar 20, 2018Guru - Experienced User
What size is the house. Sq ft.
I use a AC2200 system in my 5000sq ft house with 1 Satellite. Great coverage, range and performance. 40ft disatanct between router and Satellite.
I would not use the older extender. Use the Satellite instead.
- cndeeMar 20, 2018Aspirant
Thank you.
The house is 2500 sq. feet. The router is in an extension to the house so has to go through a former exterior wall to get to the rest of the house.
- FURRYe38Mar 21, 2018Guru - Experienced User
