cndee's avatar
cndee
Which model of Orbi should I purchase and can I still use my WN2500RP N600 WiFi Range Extender?
I currently have a Verizon FIOS router and a WN2500RP N600  WiFi Range Extender.  If I purchased the RBK30, can I still use my N600 Range Extender or should I replace the N600 and get a different mod...
  • FURRYe38's avatar
    I have similar set up here. New addtion house with older existing house.
    I would give the AC2200 RBK40 kit a try. Mines working great for me in my home. I don't think you'll need more then one Satellite. I would test with the router alone at first then see if you need to place the Satellite if needed.
    Let us know what you decide to get.
