TonyOC
May 04, 2020Aspirant
Which Orbi netgear?
Hi - sorry if this has been answered elsewhere, am new here.
Which product(s) would you recommend for
- 2 storey house
- main existing router (Virgin in the UK) on ground floor
- ethernet cabling via an old netgear switch product to 2nd floor
Keen to establish wifi on 2nd floor, and a rear flank where the wifi is weak.
Is there an option that take advantage of the existing cabling?
Many thanks
https://www.netgear.com/orbi/default.aspx
https://www.netgear.com/orbi/wifi-systems.aspx
https://kb.netgear.com/000038220/What-are-the-hardware-specifications-of-the-available-Orbi-WiFi-Systems30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
- TonyOCAspirant
Thanks
Just to expand further,
- I have a Virgin Hub 3. 0 as the internet router on the ground floor
- and a switch beside it, and ethernet cables routing to other parts of the house (2 floors above)
Struggling to understand which Orbi product i need to buy. If I buy an Orbi router and node, do I
- replace the Virgin Hub with the Orbi router
- or connect them beside each other
- or hang the Orbi router off of an ethernet cable, e.g. on 2nd floor
thoughts much appreciated!
thank you
You need to ask your ISP to see if there modem/router can be replaced by other MFr routers. Some ISPs may require there router to be used.
IF the modem has a built in wifi and router and it can't be replaced, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options for configuration with Orbi,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktophttps://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
