garyjan52
Feb 03, 2020Aspirant
Which Orbi Plugin Extender should i buy?
Which plugin extender should I buy for the Orbi RBR50?
Feb 03, 2020Guru - Experienced User
I would get a RBS50 if you can afford it. To maintain same level of connection back haul that the 50 series offers.
Is there a reason you need another RBS?
- garyjan52Feb 03, 2020Aspirant
I have the RBR50 router. Is it compatible with the RBW30 wall plug extender?
- CrimpOnFeb 03, 2020Guru - Experienced User
Yes, every Orbi satellite is compatible with every Orbi router in the same product line. i.e. the WiFi 5 Orbi, the WiFi 5 Orbi Pro, and the WiFi 6 Orbi are all separate product lines. RBR50 is in the "regular" WiFi 5 Orbi line.
