Jimm9
Jun 04, 2020Aspirant
Which Orbi Satellite to Buy?
Hi,
I have an RBR50 with two satellites that I picked up last year. I have a rather large house (over 6000 sq ft) along with a 6 car garage outside. I have one of the satellites about 45' and through 2 walls from the base unit. They are both upstairs. Beyond that and another 30' is the garage. Connectivity is spotty on the second satellite so I just moved it closer today to that position. The garage is really spotty. Should I add another satellite in the garage or should I get one of the RBS50Y or can I get both to get the coverage I want? I know you can only have 3 satellites but I believe the RBS50Y is a little different? Does anyone else have a problem getting the satellites to stay connected at this distance? I just upgraded the firmware yesterday to v2.5.1.16.
Thanks for the suggestions,
Jim
Either RBS50 or the RBS50Y. The Y is an outdoor unit so you can put it outside if you like.
- Jimm9Aspirant
Is the RBS50Y actually more powerful or is it basically the same thing? I read that it penetrates walls better. I can put it inside the garage if there is no benefit other than waterproofing.
I believe the HW is the same, just an RBS50 inside a weatherproof case..
