Brenkj
Dec 04, 2018Aspirant
Which Orbi System Should I Buy for My House
I'm looking into buying an Orbi system and I'm trying to figure out which one is best for my house. The house is about 50 years old. It consists of 2 floors of about 2,000 sf each, plus a 3rd floo...
Brenkj
Thanks for the heads up. What the difference between the small satellite units that come with the RBK23, and the larger satellite unit that comes with other packages?
Dec 05, 2018Guru - Experienced User
There are two LAN ports in back of the smaller RBS20s while you get 4 LAN ports in back on the RBS50s.
