jranaudo
Jul 31, 2018Aspirant
Which Orbi System? Totally confused!
Hi Folks,
Bare with me as my networking skills are pretty bad. I have a 2k sq ft home. Well more like 3k when you include the basement where I live. Home office is downstairs with 3 total floor...
jranaudo
Thank you for your reply.
So what would the difference be if I purchased an RBK30 with an extra satelite?
It seems like I would get better wifi with 2 additional Satellite being strategically placed as opposed to the one Satellite with the RBK40
Jul 31, 2018Guru - Experienced User
If you can place all three well with out too much over lap, it would work. 30 feet to start with in between the router and each stallite.
- twokatmewJul 31, 2018GuideAlso consider the obstructions the signal passes through. I have a 1950s-era 1200sf brick house. Plaster walls. I have an RBR50 with an RBS50 satellite. I thought it would be overkill, but no. I'm really glad I went with this over the 20-30--40 systems.
