jranaudo
Jul 31, 2018Aspirant
Which Orbi System? Totally confused!
Hi Folks,
Bare with me as my networking skills are pretty bad. I have a 2k sq ft home. Well more like 3k when you include the basement where I live. Home office is downstairs with 3 total floor...
Jul 31, 2018Guru - Experienced User
If you can place all three well with out too much over lap, it would work. 30 feet to start with in between the router and each stallite.
twokatmew
Jul 31, 2018Guide
Also consider the obstructions the signal passes through. I have a 1950s-era 1200sf brick house. Plaster walls. I have an RBR50 with an RBS50 satellite. I thought it would be overkill, but no. I'm really glad I went with this over the 20-30--40 systems.
