Appleuser2000
Apr 04, 2020Guide
Which Orbi version do I have?
I hear there are Orbi v2, how can I tell which one I have and is there a difference? I also saw some Orbi devices with only 1 ethernet port on the opposite of the 4 ethernet ports that usually comes...
- Apr 04, 2020
The exact model number should be on the product label on the bottom of the router.
For the Orbi RBR50, version 2 is the one that does not have a USB port.
CrimpOn
Apr 04, 2020Guru - Experienced User
Appleuser2000
Jun 21, 2020Guide
is it any version better or worse?
