mrchrise
May 24, 2020Aspirant
Which Orbi?
Hello, I have a standard fibre connection into the house (with Virgin Media) and currently running my computer in the office from a hardwire connection, having recently run a CAT7 connection. I want...
May 26, 2020Guru - Experienced User
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
mrchrise wrote:Hello, I have a standard fibre connection into the house (with Virgin Media) and currently running my computer in the office from a hardwire connection, having recently run a CAT7 connection. I want to move the end point to an Orbi given reviews but I don't see the need to replace the main modem- is this possible - hardwire connection from Orbi access point - therefore connecting my laptop in the office (and surrounding area) via wireless?
