MarkM13
May 22, 2021Tutor
Which product would I get w an ethernet port to connect to a console that can pair with my Orbi?
I have an RBR40 — Orbi AC2200 Tri-band WiFi Router with a satellite that plugs directly into the outlet, but it does not have an ethernet conection capability. Which product would I get w an ethe...
- May 23, 2021
May 22, 2021Guru - Experienced User
the satellites with ethernet ports are:
RBS20
RBS40
RBS40V
RBS50
