MarkM13's avatar
MarkM13
Tutor
May 22, 2021
Which product would I get w an ethernet port to connect to a console that can pair with my Orbi?
I have an RBR40 — Orbi AC2200 Tri-band WiFi Router with a satellite that plugs directly into the outlet, but it does not have an ethernet conection capability.   Which product would I get w an ethe...
