NKBoca
Nov 23, 2020Aspirant
Which satellite for my CBR40
We have the CBR40, and getting bad connectivity on video conferencing from the farthest room. Thought of using a satellite but am not sure which is better to use (RBS20 vs RBS50).
We have a 300MB internet through Xfinity.
Appreciate the feedback.
Thanks!
The RBS50 will work, just know that the wireless back haul rate of 1733Mbps that the RBS50 supports will only use 866Mpbs thats used on the CBR40. Otherwise the RBS50 will work just fine.
RBS20 or RBS40v or RBS50 will work.
- NKBocaAspirant
Thanks for your reply!
I have been reading some discussions that say that the RBS50 is not a viable or suitable satellite option for the CBR40. Do you know if it works? I am interested in it as it seems to have better throuput than the RBS20.
Netgear does not provide enough information about the compatibility of the satellites with the main router, and I want to avoid if possible purchasing the 50 and find out those comments were actually valid regarding compatibility.
