rampi
Jun 09, 2020Guide
Which satellite models are compatible with RBR50
I have RBK50 system (RBR50 router and RBS50 satellite). I am thinking of getting another satellite(s) to extend/improve the coverage. Question is which all satellite models are compatible with RBR5...
- Jun 10, 2020
rampi wrote:Was reading up a bit ... I guess my only options are RBS20 & RBS50?
No, any of the options I listed will work. I was just saying the rbs50 and rbs50y both have the 4x4 1733mbps backhaul. The rbs20, rbw30, rbs40, rbs40v all use the 866mbps backhaul. They still work fine and in many cases with a very similar performance.
Jun 10, 2020Guru - Experienced User
I wouldn't use the rbs10's.
I'd recommend these:
rbs20
rbw30
rbs40
rbs40v
rbs50
rbs50y
reason why is they're all triband. The rbs10's are dual band.
something else to keep in mind is the rbs50 and rbs50y are the only 2 that keep the full 1733mbps backhaul of the rbk50 series you're on. the others use 866mbps.
- rampiJun 10, 2020Guide
Thanks for the info.
