rampi
Jun 09, 2020Guide
Which satellite models are compatible with RBR50
I have RBK50 system (RBR50 router and RBS50 satellite). I am thinking of getting another satellite(s) to extend/improve the coverage. Question is which all satellite models are compatible with RBR5...
- Jun 10, 2020
rampi wrote:Was reading up a bit ... I guess my only options are RBS20 & RBS50?
No, any of the options I listed will work. I was just saying the rbs50 and rbs50y both have the 4x4 1733mbps backhaul. The rbs20, rbw30, rbs40, rbs40v all use the 866mbps backhaul. They still work fine and in many cases with a very similar performance.
rampi
Jun 10, 2020Guide
- plemansJun 10, 2020Guru - Experienced User
- rampiJun 24, 2020Guide
Thanks. Just wanted to update that I went with RBS20, with wired backhaul.
