RVANewbie's avatar
RVANewbie
Which satellites are compatible with the Orbi RBR20?
I just installed the RBR20 with one satellite, after MUCH trouble -- but I think it's all set now.  Questions:
  1. Which satellites are compatible with the RBR20?  I'm frustrated with the Netgear website's lack of documentation in this regard.
  2. What's the difference between the RBS20 and the RBS50?
  3. Is there a RBR20-compatible satellite with better features?
Thanks for any help -
  • CrimpOn's avatar
    CrimpOn
    Every Orbi satellite is compatable with every Orbi router.  Wall plug, outdoor, it doesn't matter as long as they are the "residential" model (not Orbi Pro or the new AX model).
    The difference between the "20" series and the "50" series can be seen on their product data sheets:
    https://www.netgear.com/images/datasheet/orbi/RBK50.pdf
    https://www.netgear.com/images/datasheet/orbi/RBK23.pdf
    It's pretty obvious that the "50" series has (4) ethernet LAN ports, whereas the "20" series has two.
    The RBS50 has (6) internal antennas, whereas the RBS20 has (4) internal antennas.  That is, the RBS20 "backhaul" signal uses the same 5G radio and antenna as the "user" 5G network.
    The RBS50 has a maximum backhaul speed (if connected to an RBR50 router) of 1,733mb whereas the RBS20 has a maximum backhaul speed of 866mb.
    As far as "features", they are the same.  Satellites do what satellites do.  The "50" satellite is "more better" IF you need more ethernet ports or IF it is connected to a "50" router.  Connected to the existing RBR20, the backhaul speed difference disappears, the extra antennas are not significant, and the only difference is those two extra ethernet ports.
    Don't know if this is what you are looking for.
    • RVANewbie's avatar
      RVANewbie
      Thanks so much -- yes, very helpful.  You communicated a lot of useful information in a relatively small space.  I think it would be very helpful if Orbi were to post this information somewhere on its website where customers could easily see it.
      Thanks again --
