jhoff909
May 18, 2020Apprentice
Which satellite's can I add to an RBR50v2?
Hi, I have an RBR50v2 and an RBS50 and am looking to add another satellite. $210 to just add a satellite (RBS50) seems high. Are there other options? Thanks! Jerry
- May 18, 2020
Yes, any Orbi satellite except for the new RBS10 will integrate with your Orbi system. (RBS20, RBS40, RBW30, RBS50Y - expensive!)
If you need WiFi coverage for one specific device that never moves, you could purchase a simple "WiFi extender" for under $50.
CrimpOn
May 18, 2020Guru - Experienced User
jhoff909
Thank you!
