yeahman
Dec 08, 2019Tutor
Which Satellites can I add
Hi I have the following : AC2200 Mini Orbi Router(RBR40) with rbw30 satellite - but would like to add another satellite - please could you advise what versions of satellites I can add to this, is th...
Dec 08, 2019Guru - Experienced User
All the satellites are compatible. But if your main router is the rbr40 you're a bit constrained by the 866mbps backhaul. the rbs50's have the faster backhaul but your primary router will limit it down.
So again, every satellite should work with yours. If the rbs50 is cheaper, go that route. but if it isn't, you won't see a benefit.
