tishij20
Dec 15, 2023Follower
Which satellites compatible with RBK50?
I am using the RBK50 kit (Router + Satellite). If I understand correctly they are RBR50 and RBS50. If I want to add another satellite, does it need to be same RBS50, or can I just shop any satellite...
Dec 15, 2023Guru - Experienced User
- CrimpOnDec 15, 2023Guru - Experienced User
https://kb.netgear.com/000062035/How-many-satellites-can-you-add-to-an-Orbi-WiFi-System
I would pick up another RBS50 on Amazon (renewed) or eBay (used).
