Anonymous
Sep 09, 2020Which VPN app will work with my Orbi Mesh?
The folks at Express VPN said their product might "brick" my router. Does anyone have a suggestion for a strong VPN application for this product? I will download to a Mac. Firmware V2.7.0.70 ...
Anonymous
Sep 09, 2020The Orbi is already behind the local provider's fiber optic modem/router. There is a way to do this for iOS use, but I don't want to go through the firmware transition without any confidence that it will work. I wouldn't know how to restore the Netgear firmware should it be a disiaster.
Here's the best link I've been able to find, but it starts out clear and ends in mud (for me.) I need the configuration in the router as that's where the Apple TV is connected, and am not interested in iOS solutions.
https://kb.netgear.com/31489/How-do-I-use-VPN-on-my-Orbi-system-with-my-iOS-device
Thanks,
Stu
CrimpOn
Sep 09, 2020Guru - Experienced User
Alas, this link describes how to set up the Orbi as a VPN "host", so that devices from outside the LAN can connect into the Orbi LAN through a VPN tunnel. I use this when I am away from home and want to check on my Orbi network, IP cameras, servers, etc.
What you want is a VPN "client" package, which the Netgear firmware does not support.
ExpressVPN has a solution specifically for AppleTV: https://www.expressvpn.com/vpn-software/vpn-apple-tv
Says it is a "Risk Free" trial. What do you have to lose?
I need to state again that I have no idea if using a VPN will do what you want. If Hulu is smart enough to know that you are not in the US, maybe they are smart enough to know that you are going through a VPN.
