Owen6936
Dec 12, 2018Aspirant
Whitelist external IP Range for Port Forwarding - ORBI RBR50 -
We use an external service that requires ports to be open and redirected to internal printers, to be able to receive and print. Hackers are scanning for open port and sending "improper" printouts to...
CrimpOn
Dec 12, 2018Guru - Experienced User
You did not say what brand/model of printers are involved. In addition to trying to block the most common types of port scanning (ping, etc.), it might be worth a few minutes to Google "how to block IP addresses from printing." For example, there is thread on an HP help site:
https://h30434.www3.hp.com/t5/LaserJet-Printing/Restrict-printing-by-IP/td-p/5981470
At message 4, "John" talks about setting up an old Windows PC as a print server, which enables all of the capabilities of Windows Firewall. He also talks about capabilities inherent in the specific HP print server they were discussing. A PC is certainly more expensive than a ream of dirty pictures, but also less costly than a hostile workplace lawsuit.
Their specific problem was related to the print server being able to block access to port 80, but not blocking access "directly to the printer." What IP port(s) are being used remotely to access your printers?
Owen6936
Dec 13, 2018Aspirant
We use several ports, like 9001, 9002, 9003, 9004, 9005, 9100. They are mapped to an internal IP address on the internal port of 9100, using the "gaming" section of the router.
port: 9001, redirected to 192.168.1.42 port 9100 (as an example).
There is only one outside range of IP addresses that I want to Allow access (passage) to and through these ports. I want to deny every other attempt/access.
The ISP is Sudden Link, they provided a ARRIS Touchstone SB6183. Modem.
- CrimpOnDec 13, 2018Guru - Experienced User
Do you have the consumer Orbi or the corporate Orbi?
(I don't know that this matters. I have no knowledge of how the corporate Orbi differs except that people claim in the forums that it is more stable. Maybe the corporate model has more "corporate features"?)
Let me guess, a VPN is not under consideration because the external service connects to printers for numerous clients and needs to treat them all alike? Have you asked the service if any of their other clients experience the same sort of unauthorized use of printers? (Maybe some have andn have implemented solutions.)
- Owen6936Dec 13, 2018Aspirant
Correct, we are just one of their many clients.
Yes I have asked, they are they are the ones that said "add a white list to your router" but did not offer any further instructions nor have the expertise to advise where (in the router settings). In other words, they CONCEPTUALLY know how to fix the problem but not in Real Life.
I'm fairly good with IT and Routers but I have looked at every corner of the router setup and do not see anywere where I can add an "approved IP range" for Forwarding.
In short I need to open those ports for ONLY one range of external IPs.
