Deech123
Mar 21, 2018Aspirant
who help me with my ORBI RBR50 and RBS50 with firmware 2.0.1.4
Hi, I bought this ORBI system 2 weeks ago.(RBR50 and RBS50). after installing these devices in AP mode, and after update, I encounter continious problems with Wifi. Let me explain how this is ...
bbunge
Mar 21, 2018Star
Unless you are on firmware version 2.1.x.x do not try to use the wired backhaul. Firmware 2.0.1.4 is the current release but there is a 2.1.2.18 that you can manually upgrade to. If you do, upgrade the satellite first then the router. Factory reset both, press the reset for 10 seconds, then st up with the satelite close to the router via WIFI. If I get a chance I'll try the RBK50 as an access point wired and WIFI and report back.
Deech123
Hi,
I just upgraded both RBS and RBR. Will let you know the results over here.
thx for the tip.
Deech
