TheBigGameHuntr
May 13, 2020Aspirant
Why Am I Not Getting the Speed
My admin app shows I am getting the more than 400mbs I am paying for but my computer speed tests are showing 1/4 on one computer and 1/8 on another. What can I do to get my speed up?
- May 21, 2020
No, 300Mpbs is a connection rate of the wifi adapter. Not wired. Connection rate is the link rate between the adapter and the source wifi signal only. The connection rate differs from actual thruput speeds.
TheBigGameHuntr
May 21, 2020Aspirant
I am running current firmware 2.3.5.32
HITRON E31N2V1
Windows 10
Cable is set up for 400 speed (I'm getting half that)
My computer is set up for wireless
Orbi admin tells me I should get more than 400. I'm getting low 200's
May 21, 2020Guru - Experienced User
What are your wired results with the PC?
What is the mfr and model# of the wireless adapter in this PC?
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
- TheBigGameHuntrMay 21, 2020Aspirant
I seem to have a hardware problem that is preventing direct connection.
Intel Dual Band N7265 WiFi4 WPA2-Personal
The main unit is on my desk less than a foot away
The sattelite is upstairs on another floor but at the same end of the house.
It's showing at 5Ghz'- Network Channel 48
Neighbors? One on each side More than 100 feet away, easily
A printer and its network is on the other side of my desk
SSID: ORBI02
Protocol: Wi-Fi 4 (802.11n)
Security type: WPA2-Personal
Network band: 5 GHz
Network channel: 48
Link-local IPv6 address: fe80::c12b:6134:85ea:6582%16
IPv4 address: 192.168.1.5
IPv4 DNS servers: 192.168.1.1
Manufacturer: Intel Corporation
Description: Intel(R) Dual Band Wireless-N 7265
Driver version: 19.51.18.1
Physical address (MAC): DC-53-60-92-2C-A5Is this helpful?
- FURRYe38May 21, 2020Guru - Experienced User
With this model wifi adapter, 200Mpbs will be about max it will see and test with:
Your wired LAN speeds should be to spec.
Just to make sure I am following, although the link says 300, that is for wired. For wifi, it drops to 200.
Is that correct?
Would you know if there is an upgrade path with Orbi (reduced cost purchase for former customers)?
Thanks for your help.
