TheBigGameHuntr
May 13, 2020Aspirant
Why Am I Not Getting the Speed
My admin app shows I am getting the more than 400mbs I am paying for but my computer speed tests are showing 1/4 on one computer and 1/8 on another. What can I do to get my speed up?
- May 21, 2020
No, 300Mpbs is a connection rate of the wifi adapter. Not wired. Connection rate is the link rate between the adapter and the source wifi signal only. The connection rate differs from actual thruput speeds.
TheBigGameHuntr
May 21, 2020Aspirant
Just to make sure I am following, although the link says 300, that is for wired. For wifi, it drops to 200.
Is that correct?
Would you know if there is an upgrade path with Orbi (reduced cost purchase for former customers)?
Thanks for your help.
May 21, 2020Guru - Experienced User
