vartistry
Aug 07, 2018Aspirant
Why Can't I Port Forward to the Same Internal Port on Different Devices?
Like many, I made the mistake of getting an Orbi system. It drops constantly and is unreliable, and I'll need to replace it soon, because it's clearly not ready for primetime. Until that day, I'd lik...
- Aug 21, 2018
Can you try Advance setup -> uPnP and turn uPnP off? Port forwarding to the same port should work after that. uPnP is turn on by default and i don't know why it has anything to do with port forwarding and also the error message is misleading.
vartistry
Aug 15, 2018Aspirant
Any more ideas on this? Do I just write this off as another reason to avoid Netgear products? This is pretty basic functionality.
