correalej
Apr 27, 2018Aspirant
Why do Devices connect to Router farther away than satellite?
I am on the Latest version 2.1.4.10. Not that it as just happened, but i have noticed out of the last 2 months with all the issues my wireless speeds have dropped. I have 1 RBR50 router (AP Mode) ...
DarrenM
May 01, 2018Sr. NETGEAR Moderator
Hello Correalej
Do you have fast roaming enabled on your Orbi system if not you may want to enable this feature in the advanced wireless settings this will allow your devices to more easily jump between the router and satellites.
DarrenM
- correalejMay 01, 2018Aspirant
Hmm i looked and no i do not have it enabled. I will play with this setting this weekend. Thanks!
