rsisson
Nov 01, 2020Aspirant
why does my Orbi not see the ipdate
My Orbi is currently on V2.5.2.4 and when I manually check for what is the current version I see there is a version V2.6.1.40 for the US market. Why doesn't my Orbi see this update and suggest updating to it when I go to "check for updates"
Obviously the same question goes for my satalites?
thanks
the newer versions are not probably set for autoupdates currently.
rsisson wrote:My Orbi is currently on V2.5.2.4 and when I manually check for what is the current version I see there is a version V2.6.1.40 for the US market. Why doesn't my Orbi see this update and suggest updating to it when I go to "check for updates"
Yesterday, My Orbi said that 2.6.1.40 was available for the satellite, but only 2.5.2.4 for the router. Today, it says only 2.5.2.4 is available for both. Add, I am in the US where at least 2.7.0.70 should be available. Netgear's firmware release process is a mess!
I remain firmly on 2.5.1.16 until there has been a concensus that new firmware is at least as good as the COVID vaccine: i.e. "safe and effective."
For example, there was a comment yesterday that 2.6.1.40 may have disabled Access Control on the web interface and tells users "use the app for that." NOT what I want have happen right now. Maybe this comment was in error. Maybe 2.6.1.40 does something so wonderful that I would be a fool not to jump on it.
Time will tell.
I think anything v2.7x isn't being offered as an automatic update or seen on the auto update servers. I think NG maybe holding those for manual updates and whom in the US region want to try v2.7x since thats mostly Parental Controls/Disney Circle FW related.
