JDhacker
Jan 23, 2022Aspirant
Why does Orbi RBR50 Ethernet connection display name of the Guest network
Have Orbi RBR50 router with wired (ethernet) connection to service provider's AT&T fiber using their 5268AC FXN router Orbi (out) ethernet feeds a Netgear GS108 switch which has an ethernet connecti...
CrimpOn
Jan 23, 2022Guru - Experienced User
This is a true puzzler. I have two Orbi RBR50's (one for actual use and one for experiments [and my spare])
The production Orbi shows up on a Windows 10 desktop as "Network".
The test Orbi shows up on a Linovo laptop as the Orbi router name. (which happens in this case to be the same as the WiFi SSID).
What is the 'name' of your Orbi?
(Found on the web interface, Advanced Tab, Setup, Device Name)
