JDhacker
Jan 23, 2022Aspirant
Why does Orbi RBR50 Ethernet connection display name of the Guest network
Have Orbi RBR50 router with wired (ethernet) connection to service provider's AT&T fiber using their 5268AC FXN router Orbi (out) ethernet feeds a Netgear GS108 switch which has an ethernet connecti...
Mikey94025
Jan 28, 2022Hero
JDhacker wrote:Have Orbi RBR50 router with wired (ethernet) connection to service provider's AT&T fiber using their 5268AC FXN router
Orbi (out) ethernet feeds a Netgear GS108 switch which has an ethernet connection to a Dell 5060 desktop.
On this desktop (Windows 10 Pro) (Network & Internet > Ethernet) it displays the ethernet icon, the name of the guest network and "Connected"
My question is why is my computer not displaying the name of the main network. I have seen other posts that say the guest network is wireless only. If I diable the guest network, the ethernet still connects with the guest name.
Can you attach a screenshot of what you're talking about? Did you at some time in the past connect this computer to your wireless guest network of that name or any other Orbi wireless network with that same name?
Windows 10 automatically creates a network profile when you connect to a network. Ethernet networks are named something like “Network,” while wireless networks are named after the SSID of the hotspot. Unlike wireless connections, there is no other "name" for the wired ethernet so the wired network name in Windows is just a string and not controlled by your Orbi.
In my experience Windows figures out that the wired ethernet is the same as a previously-connected wireless network and reuses it. So if you wireless connect to "MyNetwork" and then wired connect to the same network, Windows will reuse "MyNetwork" or sometimes give it a number like "MyNetwork 2". See my attached screenshot showing an example, where "maggie 4" is the name of my wired network and the Windows profile was smart enough to relate it to my Orbi's wireless network named "maggie".
You can also change the Windows wired network name to whatever you want: https://www.howtogeek.com/364291/how-to-change-or-rename-the-active-network-profile-name-in-windows-10/
JDhacker
Feb 04, 2022Aspirant
Thanks all for the input. I attached two screenshots, one ethernet where my Guest network is "Bestguest" and wireless is "ORBO73". Tried disconnecting ethernet, connecting wireless, disconnecting wireless then reconnecting ethernet and it still says "Bestguest"
If this is just a WIndows naming issue then I will leave it as is, but thanks for the instructions to change. My main concern was security as I was concerned that someone on my guest network would have a way to access my computer.
- Mikey94025Feb 04, 2022Hero
JDhacker wrote:Thanks all for the input. I attached two screenshots, one ethernet where my Guest network is "Bestguest" and wireless is "ORBO73". Tried disconnecting ethernet, connecting wireless, disconnecting wireless then reconnecting ethernet and it still says "Bestguest"
It is just a Windows naming thing for the wired network connection, not any indication of a security issue. Windows will not change the wired network name once it is initialized the very first time.
