atomarchio
Apr 09, 2018Tutor
Why does Orbi satellite light come on at random times during the day? RBK30
I've had the Orbi for about a week now. It seems to work fine but I am noticing the satellite light (at the top in an oval) comes on at random times. Does that mean there is a problem? Also, h...
Apr 09, 2018Guru - Experienced User
What color is the light? Review the user manua to see what the colors mean.
What is the distance between the router and satellite? Too close or too far could be an issue.
atomarchio
Apr 09, 2018Tutor
It's a solid blue light. I understand that is good.
Just wondering what triggers the light to come on? Any idea?
- FURRYe38Apr 09, 2018Guru - Experienced User
Interferences and temporary loss of signal from the Orbi router possibily. What is the distance between the router and satellite? Too close or too far could be an issue.
- atomarchioApr 09, 2018Tutor
So how would I determine if the satelite needs to be moved?
The number of times a day that light goes on?
