atomarchio
Apr 09, 2018Tutor
Why does Orbi satellite light come on at random times during the day? RBK30
I've had the Orbi for about a week now. It seems to work fine but I am noticing the satellite light (at the top in an oval) comes on at random times. Does that mean there is a problem? Also, h...
Apr 09, 2018Guru - Experienced User
What is the distance between the router and satellite currently?
- atomarchioApr 09, 2018Tutor
The router is on one end of my house and the satelite on the other. I'd guess about 50 feet.
- FURRYe38Apr 09, 2018Guru - Experienced User
I would try moving it closer and see. I have similar placement however mines about 40 feet.
but then I am concerned about not getting the coverage I need in a specific room.
Is the wifi actually working when the light comes on?
