atomarchio
Apr 09, 2018Tutor
Why does Orbi satellite light come on at random times during the day? RBK30
I've had the Orbi for about a week now. It seems to work fine but I am noticing the satellite light (at the top in an oval) comes on at random times. Does that mean there is a problem? Also, h...
Apr 09, 2018Guru - Experienced User
What is the distance between the router and satellite currently?
atomarchio
Apr 09, 2018Tutor
The router is on one end of my house and the satelite on the other. I'd guess about 50 feet.
- FURRYe38Apr 09, 2018Guru - Experienced User
I would try moving it closer and see. I have similar placement however mines about 40 feet.
- atomarchioApr 09, 2018Tutor
but then I am concerned about not getting the coverage I need in a specific room.
Is the wifi actually working when the light comes on?
