atomarchio
Apr 09, 2018Tutor
Why does Orbi satellite light come on at random times during the day? RBK30
I've had the Orbi for about a week now. It seems to work fine but I am noticing the satellite light (at the top in an oval) comes on at random times. Does that mean there is a problem? Also, h...
Apr 09, 2018Guru - Experienced User
How big is this home?
Mines 5000sq feet, router at one end and 1 satellite at the other end, 40ft est. distance in between. I have coverage inside and out side all over. No dead spots where there were a couple or very low signal when using a single router.
atomarchio
Apr 09, 2018Tutor
4500 sq ft. the Orbi router in the basement and the satelite in my home office which is the problem room for wifi in my home.
it does appear to be working fine. however, the light coming on the satelite every day is a bit annoying.
is there a way to measure if the wifi signal is dropping every time the light comes on?
- FURRYe38Apr 09, 2018Guru - Experienced User
Any chance of getting the router out of the basement on to the main floor by chance?
Or move the orbi satellite a bit closer. Like I said, could be anything that mabye causing the satellite to quicky drop or reconnect fast thus triggering the Blue LED. You can moved the satellite back.
Might even do a factory reset on the satellite and re-add it and see if it continues to appear.
- atomarchioApr 09, 2018Tutor
My cable modem is the basement. I thought the router has to be direct connect to the modem without a switch.
Or can I move the router anywhere on my network?
please clarify. Thanks.
You could use a Gb non manged switch in between the modem and router if the router is the only item connected to it to help extend it from the modem, or use a long CAT6 cable between the modem and router as an option.
