atomarchio
Apr 09, 2018Tutor
Why does Orbi satellite light come on at random times during the day? RBK30
I've had the Orbi for about a week now. It seems to work fine but I am noticing the satellite light (at the top in an oval) comes on at random times. Does that mean there is a problem? Also, h...
Christian_W
Apr 10, 2018Star
Log in to orbilogin.com and from there you can se the signal status between router and satelite.
- atomarchioApr 17, 2018Tutor
I logged into Orbilogin.com but can't find that screen.
What setting do I use to find signal between router and satellite?
Please help. Thanks.
- FURRYe38Apr 17, 2018Guru - Experienced User
User Basic, Connected Clients...
atomarchio wrote:I logged into Orbilogin.com but can't find that screen.
