robo9000
Sep 29, 2019Tutor
Why does the Orbi App REQUIRE location services to be enabled?
I downloaded the Orbi app and it won't let me continue without allowing location services on. It says it needs it to 'automatically connect to wifi'. Well, my phone already automatically connects to ...
ekhalil
Sep 29, 2019Master
As mentioned in the app, Location Services is needed to allow the app to automatically connect your mobile device to your Orbi network if you -later- change the network name (SSID), without repeating the authentication procedure.
I think Location is also used in the Orbi app mainly to select the app language.
- robo9000Sep 29, 2019TutorRight, but I could easily reauthenticate myself if I change the SSID. The app should still operate without requiring location services and as it stands you can’t.
- CrimpOnSep 29, 2019Guru - Experienced User
I reloaded the Orbi app on my Android phone just ow (version 2.4.8.816). When it asked for "Location Permission" it definitely was an option. One of those ominous warnings, "May experience reduced experience if location is not allowed." The app was clearly prepared to proceed without knowing location. Maybe the Apple app is different?
- Blanca_OSep 29, 2019NETGEAR Employee Retired
Hi robo9000
Thank you for sharing your concerns. "Location Access" permissions is needed by the app to determine the name of the connected WiFi SSID to assist with auto-connection and device detection. To ensure compatibility with the latest iOS13 changes, this was mandated as a short-term fix, but we will be looking to relaxing this requirement in an upcoming app update. Please note the app does NOT capture or submit any detailed location information. For further details feel free to contact us at netgearteam@netgear.com.
Blanca
Community Team- Bryan_AOct 28, 2019Aspirant
The problem is that the app is continuously accessing the location which drains the iPhone battery very quickly and also the comms circuitry in the iPhone gets very warm due to this way of working. If this was done as a short-term fix, then I suggest it was a crap solution.
Blanca_O wrote:Hi robo9000
Blanca
Community Team
