bottomsup
May 02, 2020Guide
Why does the router connect to devices much further than than the satellite
instead of letting the main router do it? I am trying to optimize the placement of my satelite. I also noticed that it will maintain a weaker 5ghz signal to devices than siwtching to 2ghz to ...
May 05, 2020Guru - Experienced User
Be aware its up to the connecting devices to pick and choose where they connect to, based on signal, noise and envrionment and there design.
You can help some of this by lowering the power output of the RBR to help some with this. Under Advanced Tab/Advanced Settings/Wireless Settings
bottomsup wrote:instead of letting the main router do it?
I also noticed that it will maintain a weaker 5ghz signal to devices than siwtching to 2ghz to maintain stronger signal.
bottomsup
May 05, 2020Guide
I guess as long as they are connected it doesn't really matter. I just don't see my satelight doing any of the work and want to give it some love :-)
