bottomsup
May 02, 2020Guide
Why does the router connect to devices much further than than the satellite
instead of letting the main router do it? I am trying to optimize the placement of my satelite. I also noticed that it will maintain a weaker 5ghz signal to devices than siwtching to 2ghz to ...
bottomsup
May 05, 2020Guide
It feels very unatural to nueter this powerful 6 antenna device i bought just to load balance the satelites. I guess it's a good thing since it means the main router is powerful enough to cover most devices.
May 06, 2020Guru - Experienced User
Nothing unatural about it. It's a good feature to try if you want to help devices get connected to satellites.
bottomsup wrote:It feels very unatural to nueter this powerful 6 antenna device i bought just to load balance the satelites. I guess it's a good thing since it means the main router is powerful enough to cover most devices.
