Ninovan
Oct 07, 2018Star
Why is my network map wrong
With the last update my Orbi reports that NOTHING is using my satalites. It shows everything connected to the base. I know this is wrong as each base has at least one PC -Wired- to it as well at cl...
Oct 07, 2018Guru - Experienced User
Ninovan
Oct 07, 2018Star
Ah setup...
/ Satalite #1
Comcast modem >> Orbi <
\ satalite #2
we have about 25 devices, a mix of PCs, amazon echos, cameras, VoIP boxes, media players, smart TVs, iPads, iPhones, printers, plotters, NASs, and an automation server... and a partridge in a pair tree.
the devices are even distributed about the house, so they should be distributed evenly umong the Orbi devices as well...
- cool2562Oct 07, 2018Star
If you upgraded to the new firmware you will need to restore to factory defaults and set up from scratch.
- NinovanOct 08, 2018Star
The network counties to function well, everyone is happy with the stability and speed, its just when I go to look at the network to try to head off any problems, the layout is wrong. I know the satalites are working as there are PCs connected to them that are working fine...
if if I didn't go wandering looking and trying to learn I would never know..
